You're close, but you want a small turbo, not a big one. A big turbo builds more boost, but takes higher rpm to drive. You use a small turbo that makes a completely driveable engine...
I think you missed my point. the point was to have a massive amount of energy stored in the spinning turbo before the start of the race, and use that stored power to pressurize the airbox (regardless of engine speed), not have the engine try to spin up the turbo during the race. but now that I know about the upstream throttle, it's moot.
It doesn't exactly take a big turbo to make 5-7 psi. Cmon, Evo's make 21 psi stock.
I chose 5-7 psi for two reasons: it's the most I think you can boost an already high compression engine, and it's the most I think you can count on a half-stock/half-home-built intake tract to contain. Yes, I'm fully aware that many engines that were designed to be turbo engines are running over 20 psi right off the showroom floor, but I'd be surprised if you could boost a 600 that much without custom pistons and cams
