ThinkFast
Live Long
Re my previous post, found a nice youtube vid on how to do this with a simple luggage scale.
[YOUTUBE]XaqBA-xSGbc[/YOUTUBE]
How accurate do you think a $5 luggage scale is?
When was the last time the average person checked the reading on the wrench against any standard, let alone had it calibrated back at the factory or any other servicing individual? (For most people, I bet never!) They just blindly accept the reading and move on.
So I guess we're not average.arty
Easy enough to find out. Get yourself a ten lb bag of flour and find out.
Sure - any measurement is only going to be as accurate as the gauge or scale by which we use as the basis for the measurement. That said, even cheap strain gauges like you'll find in that digital luggage scale can perform respectably well. (Welcome to world of modern electronics and other semiconductor devices.)
While tool companies are using NIST traceable scales to calibrate a torque wrench, for the casual Joe in the garage, this isn't a bad way at all to double check an old wrench. It's not rocket science - the 'pro' method isn't fundamentally different, and the dude covers most of what you'd need to know in a simplified way in that video. As you can see, even any angular error introduced is minor if you make a remote error to pull perpendicularly to the torque wrench. T = r x F.
FWIW, I'm a physicist by day. Would I use this method in my home garage if I had a nice scale? Sure. Would I use it on a funded defense project? Nope. But honestly... When was the last time the average person checked the reading on the wrench against any standard, let alone had it calibrated back at the factory or any other servicing individual? (For most people, I bet never!) They just blindly accept the reading and move on.
I look at calibration cost as cheaper than a hospital visit copay if something wasn't torqued properly through tool error
Same kind of thing happened to me. The one time I've used a torque wrench to tighten an oil drain plug it vibrated loose and started leaking.I'd be more worried about someone blindly entering an incorrect value on their torque wrench then blindly accepting the result.
The only time I've had a fastener back-out, and nearly kill me, was the last time I had a professional mechanic from a well-respected shop in SF change a rear tire for me. I watched the guy put a torque wrench on the axle nut just before handing the bike back to me... and it promptly fell off 60 miles later. By the time I noticed it the rear axle was, quite literally, inserted in the swing arm by a single thread. Tightening that nut without a torque wrench probably would have produced significantly better results for me...
I'm OK with not being average.
Seriously, it costs $45 to get a torque wrench cal'd.
(and I never realized that there is a city named Pittsburgh in China)Another problem (probably not in the case of the axle nut though) is the diff between dry and wet torque. Most torque ratings are for dry, but put anti-seize etc on it and you may overtorque it. Opinions vary so do your own research but I've seen a **40%** torque reduction claimed on wet vs dry bolt. Useful: https://www.fastenal.com/en/83/torque-calculator
thought I would put this out there:
http://www.sears.com/craftsman-1-2-...ID=11042411&utm_medium=598022_600263_11042411
Craftsman Digital Torque Wrench $56!
