ok. this project isn't dead.
i'm going to take some credit again for progress i made YEARS ago, but since i put it down in the mean time there was some measure of starting over inertia that had to be overcome.
i decided that the front end had to come off of the bike to finish welding the frame mods because i needed to flip the thing over for access... welds are ugly but will probably work.... for as long as i care to ride this thing. if i'm taking the front end off i'm not putting the original back on, nope. time to resume the swap upgrade of my dreams. it's been at least 7 years since starting this. it's time to finish.
so, i printed the lastest version of the hub to rotor spacer (white plastic) to verify fittment and as before, it's fine.
it would be a lot easier to adapt the native cbr900rr rotors to the gl1000 hub because then the original calipers 900rr would bolt on the forks no problem but.... they'd hit the spokes. also they're not spiffy enough being slightly smaller diameter. bigger is better afterall, that's why i want to ride a porky 70s goldwing?
original 900rr caliper, so close yet so far:
likely candidate Nissen 6 piston caliper from a MV F4 because why not?
annoyingly the nissen 6 piston uses i think an M8 fastener where the original 900rr uses M6, so i won't be able to use 1 of the existing mounting holes like this. drilling out the fork bracket hole wouldn't leave enough wall thickness for rules of thumb engineering, and i'll be dipped in shit if i'm going to do the calculations myself. this ain't that kind of build.
next up, finalize the spacers. i got them a little skewed to one side, no biggie they're PVC for the moment.
also get the rotor adapters carved out of some metal for realzies
also also work on the adapter brackets for the calipers, or maybe find some of the 6 piston tokicos that are a direct swap for the original 4 piston nissens that might let me use one of the original bolt locations. decisions decisions
