pvd
Psychopath
it helps to run a damp rag with some kerosene over the chain after lubing with the good oil. This gets a lot of the extra lube off the chain where it is not needed.
Sidewalk said:Back when I had a chain, I used gear oil.
Cleaned and reapplied weekly. Dirty, yes, but effective. 26,000 miles on a 1000RR and I still had another 10,000+ miles left on the chain.
Based on an estimate from the current wear level.yody said:? How do you know you had 10K left?? So you get 36K out of one chain on a liter bike?![]()
Sidewalk said:Based on an estimate from the current wear level.
I had only adjusted the chain a couple of times and was still on the very far forward edge of the wear scale on the bike. There was no obviously wear at all when inspecting it, even comparing it to other bikes.
Made a mess of the bike, but the chain was lasting forever. And I have heard of others getting up and over 50,000 on various bikes. Keep it cleaned and oiled, not dirty and waxed.
What part of "inspecting" did you miss? I didn't just oil the chain and walk away, I would check for wear on the rollers, teeth, and plates, and check stretch and tension.The FNG said:![]()
adjustment has to do more so with stretch and tension. the wear on the chain is on the rollers and on the inside surface of the side plates. i used chain wax on 1 street bike, and 2 race bikes with no problems. i agree with the "keep it clean" part... and thats about it.
