Better Earplugs?
I have a set of customs that I had done at a gun show and prefer my hearos to the custom set hands down.....
Not worth the coin IMO....
Roll em up tight, spit on em a little and slide em in...then let them expand before putting on your lid as has been mentioned above....
One other problem people experience is when they have earplugs with cords and the cord is in contact with a hard surface (edge of helmet) or a stiff collar - noise will transfer right into your ear. That's why I stopped using earplugs with connecting cords under helmets. Sure, they work the charm at a concert, on the gun range or when I'm working corners at the races but on the bike or in the race-car...nope.
An extra benefit of earplugs is keeping ants out of your ears.
Ants decided to camp out in my helmet one night after leaving it on my bike in the garage. One minute into my ride next morning I feel one of them exploring my ear and hoping it wouldn't go in, it did. It drove me crazy and I had to stop in traffic to get it out.
^^customs aren't better at blocking out ambient noise that high quality foamies like the hearos, they're just easier and quicker to insert, and they last indefinitely (unless you lose 'em).
Okay, then I'll stick with foam ones, now that I know how to insert them.
My gixxer is still damn loud though. Might have to find some kind of inserts for the pipe or something.
Moldex "Sparkplugs" are our favorites. My wife and I both make old people noises while sleeping. We sleep well with Sparkplugs.
Rick
> Howard Leights are the best I've used for both noise reduction and comfort
Another + for the Howard Leights Super Leights. They last a a good while and are nrr 33. It's pretty much all i use. The difference between a shitty nrr 28-30 vs a 33 is pretty dramatic.
Oh man, I almost wish I didn't read that. Now every time I get a little itch I'll get paranoid thinking it's a bug trying to crawl into my brain!
I've been wondering if anyone actually uses those helmet bags that come with the helmet. If I go camping or something, I know I'll use it now!
can i ask what helmet your using?
Shoei RF-1100
FYI I just had to return the headphones (unfortunately out of warranty) for repair as the right channel is dead. I am also likely going to upgrade them to dual driver...I opted for single driver since they were ridiculously expensive as it was, but the sound really muddy. With both drivers my friend says they sound great.
The earplugs have held up well. I use those and I listen to music via my SENA cranked to max....the speakers are really bad on the SENA and using the earplugs combines sound protection with actually making the speakers sound good. I find it faster to pop in the earplugs and then throw my helmet on vs. plugging in the custom earphones and then plugging them in, plus its illegal in CA to have two active headphones in at once.
How about putting a STOCK pipe on? Do you need the +4hp @ close to redline? Costwise, I'd think people would be giving stockers away... :teeth
These Howard Leight Super Leight work GREAT. I can use the same pair for about 2 weeks before they start loosing their effectiveness. Make sure you know how to put them in correctly for full effect.
And not all 33 dB rated earplugs are the same. I have a box (200 pairs) Moldex Pura-Fit earlugs that are also rated 33 dB, but they don't work nearly as well as the Super Leight earplugs.
Same ones I use. The best cheap earplugs. Should be less than 50 cents a pair.
33db reduction is about the best you're going to achieve with protection that goes into your ear, be it foam or the molded, custom plugs.
The advantage of custom plugs is more comfort than it is really effectiveness. FOr some people, things like hearos and other brands of foam plugs are uncomfortable over the span of several hours, and there is only so much noise reduction you can achieve with plugs since not all sound discerned by your eardrum enters thru your ear canal, surrounding tissue and bone transmit sound energy as well. Particularly lower frequencies, which fortunately are a less painful, though can be as damaging, as high under certain circumstances.
To achieve higher than 32-33db reduction, you have to go to things like noise cancelling or over the ear protection like shooting ear muffs, which is not an option for riding.
My advice is to try several brands of foam earplugs rated at 33 db (like Hearos blue) and to keep in mind that db reduction values are a bit non-intuitive. I've used different foam plugs next to the same loud machinery noise and the lower rated one's were noticeably "quieter" than the high rated one's. Often the material used and how completely it seals the canal (as well as other odd attentuation anomalies) can make lower rated plugs work better for you specifically than higher rated ones, softer, more porous material deadens the sound less effectively than more dense harder foam, but the softer foam fills in all the nooks and crannies in your ear to block sound leakage better than the stiffer, more dense material, and the softer material is more comfortable. Just one example of how a "better" rated plug might work less effectively for you, and be less comfortable too...
I've used those custom molded earplugs and for me specifically, they tend to stretch my ear canal painfully when used over a period of time (inserting and removing) Ironically, the 3 cent foam plugs you buy by the hundreds work better and are far more comfortable for me than $100 custom plugs. But for vanity, the custom plugs are the bomb because you take your helmet off and yank on the flourescent cord attached to the custom plugs and you look like an F1 driver as you enter Starbucks.
Abyss, TLDR, if not yet suggested, I buy/use a brand at Walgreens that come in a plastic box, and they're yellow and blue. I press them flat between finger and thumb, fold them in half, roll them, then insert in the ear canal. Not too deep, tho. Let them expand and voilà, very quiet. YMMV.
Actually, once I realized that I was stupid and using earplugs wrong and started inserting them properly, it sounds quite tolerable. I used to get this crazy vibration inside my ears, if I insert the earplugs all the way to the eardrum the noise is pretty good. Sounds loud enough for me to appreciate but not super ear-splitting Two Brothers loud. :laughing
The advantage of custom plugs is more comfort than it is really effectiveness. FOr some people, things like hearos and other brands of foam plugs are uncomfortable over the span of several hours...
That's just because they are using ones that don't fit. Getting one of those sample packs from earplugsuperstore.com can help people find the model of plug that fits them.
Very true, but 9 times out of 10, people typically grab a "one-size-fits-all" pack from CG or they grab a free sample, or get a handful from work...
The good thing is that again, 9 times out of 10, these work fine, and at the very least represent an order of magnitude improvement over riding without them :)
It's that 1 person out of 10 that needs to explore a much wider option of choices to help them with their particular need, like the OP, and a need to consider more carefully exactly how the options can be confusing or counter intuitive...
Personally, I have no trouble with the tan colored Hearos from CG. They're inexpensive and work well for me and I prefer them over my custom molded plugs (Which I misplaced too often)
The hearos are the only ones I can wear for a long period of time. The curvy shaped orange and orange/yellow ones get uncomfortable after a while. I think the hearos are the softest material available... at least that I've seen. I still prefer customs for the easy and simplicity though.
you can try surefire's, which fit into your ears so its a better fit. Price is usually 10-20 bucks depending on which model you use. Use em for shooting but should work perfectly in your situation and fit under your helmet.
Wow, thanks for that video!
I have crappy CVS earplugs, and following the install procedure in that video greatly improved the fit!
The more you know...
:thumbup
The Howard Leights are the best I've used for both noise reduction and comfort.
Me too, the orange ones with the flanged shape. Far more comfy and easier to insert (for me) than the yellow EAR model.
Count me as another tinnitus sufferer exacerbated by the stock Multi windscreen...
