u do a really good job of sounding like you are disagreeing w/ someone, when really you arent saying much at all.
also, i call bullshit of whats in bold. you are suggesting that Stoner's body position is allowing him to exit the corner with no bar inputs, ie no changes to the steering angle. yet in the next line, u ask if we use bar inputs to exit a corner... ill concede that when a GP pro has their front tire in the air while exiting a corner, they arent using any bar inputs. but of course, finishing off the corner on the rear tire just means that they set their line with bar inputs prior to the wheelie.
will u at least agree that the fastest way through any corner is w/ the least number of bar inputs as possible?... most likely 2, 1 to get into the corner and 1 to get out. and any further changes are jus wasting time/energy/speed/grip/etc.
Both my comments are interlinked. I'm not sure you understand what happens when you pull the inside bar (or push the outside bar as Zoran does). This is an added steering input which will stand the bike up, but add steering. The rider counter to added steering is moving the CG towards the inside of the apex/ corner...that's what moving weight down lower and towards the inside of the corner does; counteract the forces to the outside of the corner.
One terrible habit alot of the new riders have is using edge grip as drive grip. They don't understand the concept of drive grip taking a bike down the track and edge grip assisting the bike in pointing the correct direction off the corner. Once a rider is finishing their steering phase, they can begin to pick the bike up and accelerate (as Zoran commented on) forward, using their momentum to carry them DOWN the track and not use that momentum to carry them off the outside of the corner. I learned this only recently when I started racing Go-karts at Infineon...being concious of carrying my momentum/ acceleration down the straightaway and not off to the outside of the corner dropped my times from mid pack to qualifying on pole. It was huge.
T7 at Sears is a place where I see alot of riders make the same mistake. I'm pretty shitty at entries, but my T7 exit is where I make the money. The secret? Pretty easy; wait for the exit and don't mash the throttle until you're lined up for your exit apex. However, 9/10 riders I ride with pick the throttle up too early and are forced to finish the corner off on the extreme side of the corner. Chris (siglin) is really good there too, but most likely that one mistake of not being able to pick the bike up for his drive is what cost him traction and thus, a nasty highside. As Z-man was getting at, when you're coming off the corner, you really want to be putting the power to the ground, pushing the rear tire into the ground as much as possible as opposed to side loading the tire and using the edge grip to keep the tire hooked up on exits. That shit will only last so long before the tire's hammered. I see alot of up and coming racers complaining about tire life and grip issues after just one race/ trackday. I rarely get less than 3 races and 1-2 trackdays out of an SC1 rear and at that point, it's begining to tear but still has plenty of grip.
On that note, Kamal and I spoke on running some tire temp sensors, etc and using data Aquisiton to see if my theory is correct: that the cold tearing comes from less experienced riders using the side of the tire more than the middle and thus, not putting enough heat into the tires. Of course, this also could be less aggressive acceleration runs as well...but we'll learn something.
Corey Nuer (CT RACING...who's helping us with this test) told me that in a recent NJ moto shoot out, they ran Data Aq and tire temp sensors. Their discoveries were enlightening...that tires had cooled some 30 or 40 degrees from warmers off to track entry. Damn...! The other part that was something I'd not expect was losing about 20 degrees on a short chute straight away...which is where I'd expect more load on the tire and thus, more heat.
I say all this because I think alot of what we see in MotoGP riding isn't always for true cornering, but tire life maintenance, drive grip, maximum use of force, etc...stuff we just don't think about nor manage at a club level, but could learn to and make use of. Stoner needs to make that rear tire last alot longer than we do.
It'll work for most of our 6 lap races, but won't work well in an AMA or longer type event. To put it even simpler: Stoner is using drive grip as drive grip and putting as much power (force) to the ground in as direct a manner as he can...hence the reason he tries to carry less lean angle off the corner (but still needs steering to finish the corner). The steering angle forces are attempting to pull Stoner off the outside of his bike, hence the reason he lowers and moves his CG further to the inside while standing the bike up.
BTW, if you want to have a discussion on this stuff, I'm always up for it cause I find out where I'm incorrect and where I may really have something...but you don't have to come at it like the typical BARF Dick attitude. We're in the RC where pretty much everyone knows each other and that keeps things pretty in check (not always though!). That's not said as a mod, but just as a guy who enjoys bantering over this stuff, but I don't feel having an attitude is really productive to the discussion. I'm only sharing my insights...correct and incorrect to help you reach that next level. You don't have to take them...but I'd urge you to go and try a few and see what that does for your impressions on riding.
