Dear Plant Pimp
Status
Not open for further replies.
Jacques,
I'm really answering houseplant questions here. I knew the tomato question was going to bring more outdoor questions.
It sounds like you did some good stuff, and I'll bet you get some results. If nothing else, it's a $4 experiment. So, nothing is wasted.
JackTheTripper said:
Dear Pland Pimp,
I just planted some wild flowers in my front yard area. There was a dead space between where the grass stops and our patio is. (condo complex) The soild was pretty hard so I broke it up a bit then mixed the seads with some potting soil and sprinkeled it over the area. Then mixed it all up a bit and watered. After doing some research the soil is probably loamy but may be clay. Will I have any luck with these seads or did I just waste $4?
wiffledaddy said:
I used to pimp plants for a living.
Not so much sell, as just allow people to have a quality time with my plants. I had a fine stable of foliage.
Almost sounds like Anti's "secret beer gardens" that she has yet to show us. What happened to your foilage?
wiffledaddy said:
Your palm could be have a few different issues.
first of all, where did you get it? Sometimes, these guys come with spider mites, if they came from a substandard nursery, so you want to be watchful of that.
It sounds like your palm is having some difficulty adjusting to your water and to the new light conditions. Low-leaf drop is usually a sign of insufficient light. The yellowing is likely a reaction to the water.
that particular palm does well outdoors in a tropical environment, but they just don't seem hardy enough for our relatively frigid climate.
Tell me where it is: inside our outside; by a window? etc...
Thanks - I bought the plant at Costco. Didn't see mites or any other buggers. It was so green and healthy when I bought it too.
We have a skylight as well as a large window above our patio doors so there's definately plenty of light.
Ive been watering it with plain tap water.
Ive been considering that Miracle Grow stuff if that might help it or some other fertilizer.
There's only so many times you can do it before you burn out. You see that new and beautiful plant, just off the boat from Hawaii waiting for you to pick it out of the line up. You drive it downtown, and put it in someone's office, or someone's home. Before too long, that young, beautiful plant is starting to look run down. It's picking up trash along the way, it's losing its luster, it's being abused...
Ah, it was a dirty business; I had to get out.
Miracle grow in light solution is a good idea. Mix in the small measure per gallon of water, so you end up with a very, very light blue solution.
This plant can be tricky, because it gets fussy with dry or wet conditions. You can expect some loss of foliage initially, no matter what. Your house probably isn't as bright and warm as a greenhouse. If it begins losing a lot of fronds, or the color doesn't improve, determine if the soil seems too wet or too dry.
Best technique is to set a weekly watering schedule. In that week, the plant should go from moist soil to dry. If it dries up before a week, use more water. If it's still wet at the end of the week, use less.
what a wonderful thread! :thumbup
(sorry but the title of the thread didn't indicate to me what it was about, so I have stayed out of it until now, when I just needed to know what the hell was keeping this thread going.... afterall, it was about a drug selling pimp or something!)
Very informative indeed.
Unfortunately, we have bought almost all of our plants from Home Depot or OSH. Some of the roses have those white dusty thingies on their leaves. What is the best way fo getting rid of them?
Also, how often does one water a plant, if one doesn't know the specifics?? can watering a plant (like a rose plant, a ficus, etc.) on a daily basis be harmful to them??
wiffledaddy said:
There's only so many times you can do it before you burn out. You see that new and beautiful plant, just off the boat from Hawaii waiting for you to pick it out of the line up. You drive it downtown, and put it in someone's office, or someone's home. Before too long, that young, beautiful plant is starting to look run down. It's picking up trash along the way, it's losing its luster, it's being abused...Ah, it was a dirty business; I had to get out.
Ah, now I see how you came about calling yourself the plant pimp. Culling the young and beautiful out of the lineup and placing them in seemingly good homes and offices for people to enjoy, only to find them abused, depressed, dying, dropping foilage, etc. only after a short period of time, cigarette butts in their little pots. :cry The tragedy of the common flora.
Thanks again!
His pimp had was not strong.
The white powdery stuff is likely fungus spores. If only a few leaves are showing this, then cut them off. Wear gloves, and avoid contact with the healthy parts of the plant. If there is a lot of this stuff, you might be in trouble.
Generally speaking, most indoor plants can be put on a 1 week watering cycle. Outdoor plants might need to be watered more frequently depending on your local climate.
I'm not being a smartass -- for once -- but here is the rule: if it's dry, then water it; if it's not dry, then don't water it. The reason most houseplants get into trouble is simply because people don't check to see if the plant is wet or dry. Overwatering kills more houseplants than underwatering, but they both claim lots of plants.
Plant life is very tenacious. Given minimal attention, a plant will survive.
how long is a sufficient watering using a drip system? This is for exterior plants and a couple of small trees.
Dunno. Outdoor watering is complicated because there are so many variables: local climate, soil type, plant type, average wind direction and strength... you get the idea. Your best bet is to get the New Western Garden book, check to see what your zone is, then have a look at the individual plants you want to care for.
Sorry, can't help with that. If you have a houseplant question, though, then lay it on me!
(Since most of us surf from here...) What's a good plant for us cubical dwellers?
I'm curious too. What's a good plant for a place that really only gets flourescent lighting?
You've probably seen these guys around most offices, but here are the easiest plants to deal with given minimal light, forced air heating/cooling/ and the standard amounts of neglect.
This is a pothos, a very cheap and easy plant
Another easy one, an aglaonema. This variety is the silver queen
Another ag, the emerald beauty
the ubiquitous spathophyllum, or peace lilly. Its main appeal is the ability to flower in relatively low light.
There are more esoteric choices that can live in the boxicle environment, but these are the easiest and safest.
Dear PlantPimp,
I have a cat the chews up all my houseplants. Are there plants that taste like poo to a cat but won't harm them? I miss having plants around inside but it's just a waste because as soon as we turn our backs, Desmo(the cat) starts chomping the leaves or whatever he can chew on.
Cats need to eat greens, but they shouldn't eat your houseplants. Some of these common houseplants are poisonous or toxic, and can do your cat harm.
Get some kitty grass, which is a mix of sprouted seeds that have nutrients most house cats lack in their diet. Encourage the snacking on this, and discourage the houseplant snacking with a spraygun or -- if you have a cat like mine that understands English -- by telling it to stay the hell away from the houseplants.
Plant Pimp,
If I may be so bold as to intrude on your thread....
Cats are like bunnies - they like to chew shit, particularly leafy green stuff. The key is to give them some aminal-friendly alternatives so they won't go after your belongings. If that doesn't work, a spray bottle full of water and a firm "BAD KITTY/BUNNY/FAT BASTARD!" will help deter them.
humbly,
fan of plant pimp
Plant Pimp,
Someone gave my mother-in-law a baby tomato plant. She wants me to plant it in a pot so she can grow it on her balcony. How big a pot do I need?
Whodat: this is an outdoor plant question, but I can help. A tomato needs full sun, and a lot of water.
You should do the container planting in steps. A 1 gallon to 5 gallon to 15 gallon plastic nursery container is your best bet. Ask at a nursery for the containers, they should give them to you or sell very cheaply. If you buy some other stuff, the more likely they are to give the containers. You want to use a good soil mix that retains moisture. Tell them precisely what you are looking to do and ask for the best mix.
Tomatoes not planted in mother earth need to be fed regularly.
plantpimp
I'm moving this week into a new home that will be all mine for the 1st time as an adult.
I love "fern" type plants/trees and the ex never let me get any.
What is there along those lines in which I could decorate my new home with that would be able to withstand Sacramento valley climate?
You know what would be helpful, is if you could send me pics of the location, and indicate which direction the windows face.
Also, some idea of the temperature range of the room. Sac is hot, I know, so will you use the AC, or is going to be ambient valley heat?
also, honestly, how diligently will you maintain, water, and dust the plants?
I'll give you good advice, but will probably recommend expensive-ish plants. However, they will last a lifetime if properly placed and maintained. If you are not really into the maintenance, we can probably get you set up with something inexpensive that you can replace from time to time.
Status
