wiffledaddy
Gorn Star
Miracle grow in light solution is a good idea. Mix in the small measure per gallon of water, so you end up with a very, very light blue solution.
This plant can be tricky, because it gets fussy with dry or wet conditions. You can expect some loss of foliage initially, no matter what. Your house probably isn't as bright and warm as a greenhouse. If it begins losing a lot of fronds, or the color doesn't improve, determine if the soil seems too wet or too dry.
Best technique is to set a weekly watering schedule. In that week, the plant should go from moist soil to dry. If it dries up before a week, use more water. If it's still wet at the end of the week, use less.
racercutie said:Thanks - I bought the plant at Costco. Didn't see mites or any other buggers. It was so green and healthy when I bought it too.
We have a skylight as well as a large window above our patio doors so there's definately plenty of light.
Ive been watering it with plain tap water.
Ive been considering that Miracle Grow stuff if that might help it or some other fertilizer.
The tragedy of the common flora.
