AbsolutEnduser
bike r
this sounds like it might be a crappy cheap machine indeed; if the water is on top of the portafilter after making the espresso, there are two reasons:I'm sure the bulk of it is user error on my part. There are a few things that bother me about this machine though. Mainly that it's kind of cheap and I can never get the fucking portafilter thing off and I spend five minutes wrestling it back and forth up and down and then eventually it just pops off and spills everywhere.
- crappy machine, so, any of the machines suggested above, incl Andy's will be better--b/c they have the so called "three-way valve" which will suck-up all the water before you remove the portafilter
- your grind might , be too fine. (In which case the same will happen with the Breville) Or you might have both problems, fine grind, and a machine that doesn't "suck up the water"
but the problem is, when you get A New Machine, you could still have problems with grind, etc... e.g. a grind that's too fine, might create the s.c. "holes" in the puck and the water will get through them for an easy path--giving you watered down crappy coffee.
These types of machines have many variables.
