Cookie Monster
noob
Sorry for the double post and late reply on some of these posts... it takes forever to type but I am reading all the posts and appreciate all the feedback!
You're right, I won't be taking off the feelers in the future. I understand that they were not the cause of my crash and that had I listened to them earlier, I might not be in the situation I am in now.
In the future, I'd like to take some advanced riding courses to work on body position, as well as just slowing down in general. The main thing that I've learned is that even though I escaped with relatively few injuries, I still have a damaged bike, shredded gear, medical bills, and 6 weeks of sitting around in casts missing a lot of riding and other events, all because I was riding too fast around one corner. In the end, it really isn't worth going fast considering the consequences. I'm young and dumb, though, so I guess I had to learn the hard(ish) way.
I also think Enchanter made a great point that my comfort level far exceeded my skill level. For some reason I was comfortable riding at speeds I might not have had the skill to ride at so in the future I need to work on making those more equal.
I don't believe I was on the gas yet, which probably led to an unweighted rear tire, made worse by the bumpy surface as well?
Yep, a part of the problem definitely came from me trying to ride the equivalent of a bus like a Miata down Redwood Road.
And yeah I have given up on trying to drive a manual with one foot. Mainly for the safety of others.
I did have my upper body turned into the corner, but I don't think I was gripping the tank as tightly as I should've been. I also do need to work on being lighter on the bars.
One question, though: how does being light on the bars allow me to lift my butt off the seat?
Nope, I was riding the supermoto in the video, but we switched back after and I crashed.
Definitely true about having nothing to prove. I'm just so used to driving quickly in my car on Page Mill and Skyline that any time I see twisty roads I just want to go fast. It's something I need to work on for sure.
I suspect that at the pace you were going, the bump would have taken you out regardless.
Weighting the outside peg: I'm not certain that it guarantees less lean angle, but it does give greater traction by driving the tyres a little more into the road, vs weight on the inside offering a greater horizontal force (less grip). And if you have all your weight on the inside peg, the rear might skip when you dig in, which seems to be what you are describing.
Taking off the feelers: well, honestly I'm not sure how wise it is to remove them. Why do you think they are called feelers? You didn't fall off because of the feelers really , you fell off because you were going too fast, and you had a canyon-load of warning about that from the feelers, which you ignored.
Sounds like you know what happened - you hit a bump mid-corner on a (relatively) strange road - so good for you for seeing that.
So what are you going to concentrate on so you can ride smarter, not just faster?
You have most of it covered Cookie, I feel like you have a good grasp of what happened and how to prevent it in the future.
I agree that weighting the inside peg contributed to your lowside. If you had weight on the outside peg and gripped the tank with your outside leg it's possible you would have made it over the bumps. This is under the assumption that your rear lost traction.
If your front lost traction I would say that trail braking to the apex would have kept the contact patch better planted over the bumps.
Were you on the gas yet? Or were you coasting leaned over going over bumps?
Raga, from your description it sounds like there were a couple of things that might have contributed to the crash. Both the weighting of your feet and it seems like the suspension was not loaded for max grip. You said that you had finished braking and then leaned the bike over, seems that without being on the throttle the rear would be somewhat unweighted and weight bias would mostly on the front wheel with the significantly smaller contact patch. Then your peg feelers hits, then came a bump in the road. Does that sound about right? If it is, then yeah, you probably lost the rear tire. Partly because of the bump and unweighted rear tire, or peg feeler digging in, but mostly because (as you yourself pointed out) you were trying to ride a sport touring bike like a much lighter, longer travel sumo...lesson learned. Relatively cheaply too...heal up man. Jackie was saying you're trying to drive with your left foot? A little heel toe action?You dork! You want a body cast?
I think you have the generality of your incident well covered. The only other thing I would suggest that may have helped, but may be something you'll need to train yourself to do (starting at a slower pace of course) is to really support yourself with your lower body, while keeping your upper body turned into the corner (which will naturally have you supported by your outside leg).
The key here is to be super light with your hands after initiating the lean - that will allow you to lift your butt slightly off the seat as soon as you hit bumps like that, and being light on the bars will allow the tires to track where they need to.
RWR is rough to ride quickly if you're a little stiff on the bike. Not a road to max out your available lean, either, as far too often cars decide your lane is available to them, and you may need to suddenly adjust your line tighter - if you're dragging pegs regularly, that option is removed from your escape options.
I thought the guy on the FZ crashed trying to keep up with the motard? I explained why I think he crashed - outriding his skill level basically.
Next time, probably stay in your comfort zone, there is nothing to prove my good man![]()
