nvp
Ownership hasn't changed. They just changed the name because they added more makes in the showroom.
Previous BIKE owner, not dealer owner
I'm betting it has nothing to do with burned valves and fuel/air mix and pipes. 'Likely a mechanical failure.
Not quite. The lambda sensors will only adjust the mixture when the system is operating in closed-loop mode, ie at lower rpm's and smaller throttle openings and even then only if the fuelling requirements are within the parameters of the OE map in the ECU.
Well, all that's simple enough. It's the alphabet soup they use to designate all the different models. Welsh makes more sense to me.
BMW boxers in general tend to consume oil. But the oil seems to evaporate in the crankcase.
The bike has a full exhaust system that probably wasn't tuned for the bike. It's an illegal system.
I'm sure the rest of the anti-BMW crew hopes for the same outcome.
I'm not anti-BMW. Just sayin' that based on what we've heard from the OP that all the valves were crunched on the one side, that points to a cam that stopped turning. And thus, to some sort of mechanical failure in the cam drive. If it was a burned valve, more often than not, they don't just fall apart. Could happen, but not usually. Besides, unless it's a really radical exhaust, most modern fuel injection systems can compensate. It's also sad to hear there's more than a few instances of this happening on the 1200's as I've been thinking how nice it would be to have a newer GS.
On some of the German Boxer sites, they seem to check their valve train on a VERY regular basis...
My dad was going to buy a BMW and move away from Ducati because of the lower maintenance...then he went to MotoMarin and found the valve check/adjustment interval was identical to his...and only about $100 cheaper...so he still rocks the 4V ST4S and gets his free water at AMA/MotoGP races...
It's probably $100 cheaper to check the valves, but if there's much adjusting I'd think the Duc would be more.On some of the German Boxer sites, they seem to check their valve train on a VERY regular basis...
I'm also wondering what you and your brother have in common.
