RD250: Going with the flow...
I set the squish at .95mm...and dowelled the heads to the cylinder, so they are on center.
I adjusted the rearsets to move the pegs to a more human position. I'll junk these and make something better soon as they're godawful but they work for the time being.
I send cad (yes CAD!) files to Send Cut Send to get a disc spacer and fork bracket made to fit the FZR600 disc and R6 caliper (thanks to a gentleman on 2strokeworld for the bracket file.)
Fitted banshee inlet rubbers with crossover and reed spacers for a bit less crank case compression. Made new slip collars and silencers, with billet end caps from the lathe. And finally got it going....145psi comp and will need some jetting next week, but it sounds crispy and hopefully should make for bigger wheelies.
Excellent work Joe. That little screamer is going to run really good.
Gave it a good few rips through 2nd and 3rd yesterday and it pulls very strongly! Need to do a bit more jetting tonight.
