Whammy
Veteran of Road Racing
- Joined
- Jun 17, 2003
- Location
- Nampa Idaho
- Moto(s)
- 2012 CBR1000RR
2018 Ducati Hypermotard 939SP
- BARF perks
- AMA #3283620
Rabbit holes and parts Jacuzzi's I love it.
Wish they sold float needles![]()
Thanks Scott. Lots of info online for the sister bike VFR400 NC30 but not so much for the RVF400.Hey Rick. Thanks for documenting all of this and the great photos of all of the parts. I'll never deal with a bike like this, but what you've done here should be valuable to anybody else who does.![]()
You can get them on eBay from a local (US-based) seller. Search for 16011KCK910 on eBay. Or K&L 18-8953.
EDIT: $30, okay maybe I can splurge
. I'll do a vacuum test for assurance.
FWIW I think mine [float valves] are fine. For a visual check I looked at them under magnification and they look smooth and supple.
..... but I don't plan to do this a whole lot if ever again.
The size of the drill bit doesn't matter.......it is a static setting. As long as the same size is used....then the gap...the size of the drill bit will be the same on all, even with the drill bit removed.
With a multi cylinder engine that is individually carbureted, sync does matter in idle and smooth acceleration and deceleration.
Take your cb1.......adjust one sync screw slightly and then tell me the idle doesn't change.
Further, to tweak the mixture screw is the fancy 90 degree screw driver recommended? Any ideas for DIY version?
What else do you have hidden in that shed.
Trail 70?
The rest was boring gardening stuff, an ancient electric kiln, furniture, snorkeling gear, and two Whammo Slip 'n Slides. Right. Will re-shim and move on. Thx.Just trust that you're measuring them the correct way now and re-shim them as needed. No need to do a complete engine disassembly when you've not even fired up the bike.
what to do at this point - trust i did the inspection correctly this time and go about re-shimming the valves and move on
). We used a milk crate to prop up the bikes. Yes, the lucky SOB gets to work in his living room. Wheel 1 went perfectly. 2 and 3 wheels each had to be done twice due to pinched tubes.
Eventually after essentially 6 attempts the 4 wheels were shod with new Pirelli rubber.
