Lorry
Riding away on a bike that's on fire isn't an option![]()
It looks way cool if you can pull it off though!
And on this well beaten topic, you shouldn't have to get out of your car to refuel if you bring passenger(s). Have them do it.![]()
From Pashnit...
#6.
Filling your motorcycle.
When you are filling your motorcycle please get off of your bike. Do not fill it up while sitting on it ( we are all guilty of this one even me ) because if you have a static fire you may jump off of your bike causing it to fall over and spilling gas making the fire bigger and destroying your bike. Also while fueling ( especially if your bike has a plastic gas tank ) try to make sure that the filler hose is touching the sides of the tank where you fill it. And last but not least try to keep the filler hose as close to the fuel in the tank as possible to prevent static. A little known fact is the splashing liquid creates static. A good demo of this is when you fill a bucket with a hose and the water is splashing around it IS creating static. whereas if you were to submerge the hose it is still filling the bucket but not splashing around it is not creating static.
http://www.pashnit.com/forum/showthread.php?t=18451
My ST is uber comfortable, but I still want to get off the damn thing from time to time.
And, of course, it helps that it holds damn near 7.5 gallons, so I'm not concerned with holding the bike vertical to get the last few drops in.![]()
............................If there's a fire and you're sitting on the bike chances are you're gonna jump off the damn thing letting it hit the ground, not helping the fire or your bike at all.........................................................................
i'm low on gas... probably will be my last post since I am going to explode later tonight
Honestly, how long can this thread go on?
In-ride refueling is the answer...
You hit a button on the left grip and a docking nozzle extends from the front of your bike... You then track the flying tail boom refuelling hose coming out the back of a KC-135 Goldwing with gas storage in all the luggage compartments, latch on... top off, then break contact and wait in the IP cue as the other bikes in the squadron refuel.
