12/4/21
More wheel polishing, well, sanding today. On the front wheel only. I used the mini DA starting with 240 grit and it turns out my kit of 3 inch sanding discs I bought steps up to 600 from 240. Nothing in between. Weird. But it actually appears that this will work out. I tried buffing after the 600 and it works if I can get really hard pressure but when I get into the tricky curved areas if it gets stuck it will smooth out the sharp edge. So that’s not gonna work. I’m going to DA with 800, then 1000, then see if that will buff out without so much pressure. This is taking way too long.
12/5/21
It’s quite foggy out this morning so screw the wheel polishing task.
Today I brazed the fork cartridges. I think it came out pretty good. Especially for having never done it before. The careful filing took a bit of time.
One done, one to go.
Done. Except for making the emulators fit properly. Are you there Julian?
Brazing video
[YOUTUBE]7-vm-vRPvM8[/YOUTUBE]
12/5/21
Brazing video
