DannoXYZ
Active member
- Joined
- Apr 24, 2006
- Location
- Mesa, AZ
- Moto(s)
- CB125T EX250E Ninja250R racer CBR250R-MC19 CBR250RR-MC22 NSR350R-MC21 VF500F CBR600RR VFR750
- Name
- Danno
- BARF perks
- Barf Roadside Angel
Actually the reinforcement strips should be on the sides so that the vertical loads goes through the plane of the material.Also, if you want to stiffen up the back half of the subframe, just weld some strips of steel to the top and/or bottom of the tube. If you plan to reinforce the back half of the subframe, definately add a gusset as you will have a stress concentration at the joint you have drawn.
Imagine taking a flat metal ruler and laying it flat on a table-top. Hold down near the middle and lift one end, it bends upwards.
Now flip the ruler up so that it's laying on the long edge vertically. Hold it down by the middle and try lifting an end up. It doesn't bend one bit and is much stiffer when handling loads in-plane.
