Too bad we live in CA. Otherwise I'd probably pick up a Nagant too.
[youtube]vvF4yurWSc0[/youtube]
Well, for trap you want a more full choke depending upon distance, and for skeet you want a more open choke. What choke tubes does the gun come with? They usually come with three or four. Just use the full or modified at trap depending upon the distance and use your IC for skeet.
Make sure the barrel takes adjustable chokes. You should see if there's a package deal with the chokes. But for starting out it really doesn't matter quite so much. Just get out there and practice.![]()
"Maynard".hrm... which to go with is the question?
prince50 mag lock : http://www.riflegear.com/p-57-prince50-mag-lock-kit.aspx
or bulletbutton :http://www.riflegear.com/p-193-bullet-button-bullet-tool-combo.aspx
With the bullet button, a pin or punch is required. Whereas with the prince50 you need that allen wrench, except you can still use the prince50 like a normal mag release button if you leave the screw turned the other wayIm leaning towards the prince50.
makes me want an AK even more*want the one exactly pictured*
damn you Windy...!!!!
http://www.riflegear.com/p-268-raddlock-ak-series-magazine-lock-with-key.aspx
makes me want an AK even more![]()
