Burning1
I'm scareoused!
And is this bikes going to be a better track day bike than the new R3?
We aren't really sure right now. The R3 is a ~330cc I twin with a diamond type steel frame and conventional forks. The RC390 is a 375cc single, with a steel trellis frame and upside down forks.
Both are relatively modern fuel injected designs. Power output from the engine appears to be similar; both target A2 license in the UK.
It remains to be seen what the potential of each engine is; the RC390 seems to support generous over-rev, but it's entirely possible that the engine is tuned much more aggressively than the R3 offering the R3 much more room for gains, even within the restrictions of the AFM prod class.
Frame and geometry wise, the RC390 appears to be sportier than the R3; it features a steeper rake angle, a sturdier frame, much better forks, and lower handlebars than the R3. We're pretty sure the RC390 comes with cartridge internals standard, the R3 comes with traditional piston damping rods; similar to the Ninja 300.
With that said, you can buy production legal drop-in cartridge kits for the Ninjette, R3, and RC390 if you wish, so the internals aren't as big a deal as they should be. The RC390 has 2mm thicker upside down forks, which are an advantage. Both bikes have a 3" rim up front, and fit a 110/70/17" front tire.
On the rear end, the RC390 has an aluminum swingarm and a 4" rear tire, but does not have a linkage for the shock. The R3 has a steel swingarm and a slightly narrower rear rim, and fits a 140mm tire standard. This isn't a huge disadvantage since neither bike is powerful enough to really benefit from large tire sizes, and availability on 140mm tires has been improving.
ABS is standard on the RC390 but not available on the R3. AFM rules have been updated to permit removal of the ABS system.
Other than that, the R3 is $500 cheaper.
As for the Ninja 300? It's major advantage is that it's out, right now. The ergonomics are less aggressive than the R3, it's forks are a bit thinner, and the frame is a very very old design.
