Burning1
I'm scareoused!
Not sorted out by Kawasaki - sorted out by racers by modifying the drain plug. ...assuming IRC.![]()
Ahhh! Got it. Thanks.
Dealer says early April. No spec sheet yet, so no confirmation on slipper clutch.
I will say that I dug through the Fiche and didn't see any sign of a slipper in the 2015 US Duke. No guarantee that info is accurate, however.
I have a deposit down at motor cafe but chances are pretty good I'll wait till 2016 for a slipper one if that was the case.
fos373 said:The good:The bad:
- Overall the bike is pretty light (compared to Ninja 250) but not as light as (and can be expected) as a 450mx. I easily unloaded it from my full size truck by myself (after a day of skiing and in freezing cold weather). I would not have done that with a 600 or even a 250.
- The fit and finish of the fairings, headlights, seat and controls are very good. Most of these will be sold off as they aren't needed.
- The R&G case covers (obviously an aftermarket product) fit perfectly and were easily installed.
The front brake caliper bolts are a 8mm x 1.0 pitch x 65mm long. Try and find a replacement for that.... (remember, it will be raced so I was drilling for safety wiring and generally have spares in case something happens).
- The upper clip-on / triple clamps are junk. The bars are held in place by two very small hex bolts and the bar itself is proprietary and tapered at the end. It would have been just as easy to use a standard replacement bar. Regardless, I'll fit real clip-ons below the upper triples.
- The battery is located under a cover in front of the gas tank. There's a separate plastic cover that is released from under the seat. It's a pretty crappy design and will break easily.
- The stock rear sets, well, they're like most stock rear sets and aren't the best.
- The stock windscreen is way too low and wraps around the side of the bike.
- As it is low it will offer minimal wind protection.
- The wrap around design - why??? One tip over and the whole thing will shatter. Confusing.
- My biggest gripe - the bolts used on most of the bike are pretty sub-standard and are odd sized.
The pinch bolts for the front axle are a more normal 8mm x 1.25 pitch but the Allen bolt heads themselves are pretty soft. I think they sourced them from Ace Hardware.
I haven't taken the rear sets off yet, as the adjustable KTM's are still on their way. However, the mounting bolts look pretty junky as well.
It seems that I have more complaints than good, however it is much better than a Ninja 250.
The overall quality is very good and it's a much more thought out bike and will likely be a better performing bike than bikes in its category. Compared to a Ninja 250, CBR 250, etc - hands down this bike is much better!! If I gave a review of my Ninja 250, everyone would be appalled: It's fat, slow, doesn't want to turn, the suspension is mushy and crappy at best, slides when pushed, louder than hell with an open exhaust, has to be beaten to do anything and has no real power.
Nothing beats that bike for all day comfort
Uhh, pretty sure my 990 SMR w/ ergo seat beats it![]()
I think he means with both wheels on the ground.
A lot of the reviews I've seen say the KTM's brakes are the worst of the three between the Ninjette, R3, and RC390. Not that it couldn't be fixed easily...
At this rate, I'm starting to doubt if we'll see them in April. They haven't even hit KTM's webpage.
I don't know if the bike are actually there but if you look on cycletrader Paso Robles has a duke 390 and an Rc390 with prices listed. It does not say taking deposits next to the price like some say
edit: I just called and they said any day now![]()
