BARF Militia
I know I've said it before, but I'd just like to reiterate that grenade pouches are the perfect size to hold 2x 10rd AR15 mags. Reorganizing my range bag and found a couple extra grenade pouches to stick on the outside. More mags loaded + ready to go at home, less time spent loading at the range.
Yup Yup. Oddly enough, you can usually find them in damn near every pattern (camo or solid), In stock, just about everywhere.
I was at the range with my wife this past saturday and we put about ~500 round through the GSG-522. Then, it suddenly started either jamming or automatic fire.
After a few instances of fully automatic fire I decided that it's probably best to leave the range before I get into trouble.
I cleaned and oiled it before going. I was using Federal bulk ammo.
I noticed my barrel breech was sticking out a bit further than normal, which could have caused the full auto fire, seems like something got loose. I haven't taken it apart yet. Is it safe to use blue loctite in a firearm?
What do you mean "barrel breach sticking out"? What you have is most likely slamfire. Firing pin is stuck in forward position.
Breech is just a opening.
Post a pic
The square part of the barrel that is closest to the ejection port is visibly sticking out...
Ignoring the text on the picture, the barrel breech is sticking out on the right, but it shouldn't be.
Maybe their translation for that part is supposed to be "bolt" (it look like it according to the manual)
breech is circled in red
Yeah, and that outer part around the barrel opening is sticking out into the ejection port while it shouldn't be.
I'll break my rifle down tomorrow night and have a look.
Also, I had a really hard time zeroing a holographic sight but was able to zero a scope without problem.
I have a laser boresighter but it's not visible from 50 yards, obviously. Any tips?
I go to a range with a dirt berm and shoot at the berm and get a rough sight in to where the dirt flies up. After than I'm usually on paper and can work from there.
